〖国外标准〗 今日: 0|主题: 1098|排名: 58
预览 ASTM E 8金属拉伸标准测试方法 杨博 2007-9-19 04955 杨博 2005-9-19 20:19
预览 ASTM E 3-2001金相试样的制备方法 杨博 2007-9-19 05545 杨博 2005-9-19 20:19
预览 AMS 2759-2C 低合金钢零件的热处理 qysjx626 2007-9-18 06331 qysjx626 2005-9-18 19:17
预览 ASTM F 606M 螺栓垫片机械性能测试方法 杨博 2007-9-5 05547 杨博 2005-9-5 12:47
预览 ASTM F 593-02 不锈钢螺栓,螺钉 杨博 2007-9-5 06102 杨博 2005-9-5 12:47
预览 ASTM F 136 TC4钛合金 杨博 2007-9-5 05793 杨博 2005-9-5 12:47
预览 ASTM E 1447 钛合金中氢的测试方法 杨博 2007-9-5 06131 杨博 2005-9-5 12:47
预览 ASTM E 1251铝合金光谱分析方法 杨博 2007-9-5 06358 杨博 2005-9-5 12:47
预览 ASTM E 1077-1991 估计钢样品脱碳深度的试验方法 杨博 2007-9-5 05535 杨博 2005-9-5 12:47
预览 SAE J406 1998 Methods of Determining Hardenability of Steels xhongjun 2007-9-1 06872 xhongjun 2005-9-1 16:05
预览 ASTM A 48/A 48 M Standard Specification for Gray Iron Castings1 杨博 2007-8-28 05969 杨博 2005-8-28 23:31
预览 ASTM A 105/A 105 M Standard Specification for Carbon Steel Forgings for Piping A 杨博 2007-8-28 05219 杨博 2005-8-28 23:31
预览 ASTM A 106/A 106 M Standard Specification for Seamless Carbon Steel Pipe for Hig 杨博 2007-8-28 05941 杨博 2005-8-28 23:31
预览 ASTM A 561-71 Standard Practice for Macroetch Testing of Tool Steel Bars1 Steven 2007-7-5 06456 Steven 2005-8-24 19:20
预览 JIS G 4313-1996 Cold rolled stainless steel strip for springs williswon 2007-7-16 05678 williswon 2005-8-24 16:52
预览 JIS G 0562-2004 钢铁的氮化层厚度测定方法 williswon 2007-7-18 07211 williswon 2005-8-15 23:26
预览 JIS G 0563-2004 钢铁的氮化层表面硬度测定方法 williswon 2007-7-18 05855 williswon 2005-8-15 23:26
预览 ASTM A 276-04 Standard Specification for Stainless Steel Bars and Shapes 杨博 2007-8-10 07080 杨博 2005-8-14 14:26
预览 ASTM A 240/A 240M-04a 杨博 2007-8-10 06842 杨博 2005-8-14 14:26
预览 ASTM A 179/A 179M-90a Standard Specification for Seamless Cold-Drawn Low-Carbon 杨博 2007-8-13 06454 杨博 2005-8-14 14:26
预览 ASTM E 2142-01 Standard Test Methods for Rating and Classifying Inclusions in St 杨博 2007-8-13 06731 杨博 2005-8-14 14:26
预览 ASTM A 372/A 372M-03 Standard Specification for Carbon and Alloy Steel Forgings addle 2007-6-29 06632 addle 2005-6-29 19:17
预览 SAE ASM 2759/11 Stress Relief of Steel Parts 耕夫 2007-6-13 09460 耕夫 2005-6-29 19:03
预览 SAE ASM 2759/10 Automated Gaseous Nitriding Controlled by Nitriding Potential 耕夫 2007-6-29 06317 耕夫 2005-6-29 19:02
预览 SAE ASM 2759/8 Ion Nitriding 耕夫 2007-6-29 06586 耕夫 2005-6-29 19:02
预览 SAE ASM 2759/7A Carburizing and Heat Treatment of Carburizing Grade Steel Parts 耕夫 2007-6-29 06682 耕夫 2005-6-29 19:02
预览 SAE ASM 2759/6A Gas Nitriding and Heat Treatment of Low-Alloy Steel Parts 耕夫 2007-6-29 06605 耕夫 2005-6-29 19:02
预览 SAE ASM 2759/5D Heat Treatment Martensitic Corrosion-Resistant Steel Parts 耕夫 2007-6-29 08136 耕夫 2005-6-29 19:02
预览 SAE ASM 2759/4B Heat Treatment Austenitic Corrosion-Resistant Steel Parts 耕夫 2007-6-29 06609 耕夫 2005-6-29 19:02
预览 SAE ASM 2759/3D Heat Treatment Precipitation-Hardening Corrosion-Resistant and M 耕夫 2007-6-29 08318 耕夫 2005-6-29 19:02
GMT+8, 2026-7-19 00:38 , Processed in 0.026500 second(s), 14 queries .
