〖国外标准〗 今日: 0|主题: 1098|排名: 6
预览 SAE AMS 2759/2C Heat Treatment of Low-Alloy Steel Parts Minimum Tensile Strength 耕夫 2007-6-29 07190 耕夫 2005-6-29 19:02
预览 SAE AMS 2759/1C Heat Treatment of Carbon and Low-Alloy Steel Parts Minimum Tensi 耕夫 2007-6-29 08606 耕夫 2005-6-29 19:02
预览 SAE AMS 2759C Heat Treatment of Steel Parts General Requirements 耕夫 2007-6-29 08111 耕夫 2005-6-29 19:02
预览 ASTM E 8-04 Standard Test Methods for Tension Testing of Metallic Materials wonla 2007-5-4 07152 wonla 2005-6-29 15:01
预览 ASTM E8-03 Standard Test Methods for Tension Testing of Metallic Meterials yahoocomcn 2007-6-9 08043 yahoocomcn 2005-6-29 14:59
预览 DIN 50602 Microscopic exmination of special steels using standard diagrams to as CL60 2007-3-17 08259 CL60 2005-6-29 14:56
预览 ASTM A 858/A 858M-00 famenvalve 2007-6-27 07010 famenvalve 2005-6-29 14:50
预览 ASTM A 738/A 738M-03a Standard Specification for Pressure Vessel Plates, Heat-Tr famenvalve 2007-6-27 07161 famenvalve 2005-6-29 14:50
预览 ASTM A 729-93 Standard Specification for Alloy Steel Axles, Heat-Treated, for Ma famenvalve 2007-6-27 06850 famenvalve 2005-6-29 14:50
预览 ASTM A 713-93 Standard Specification for Steel Wire, High-Carbon Spring, for Hea famenvalve 2007-6-27 07173 famenvalve 2005-6-29 14:50
预览 ASTM A 645/A 645M-99a Standard Specification for Pressure Vessel Plates, Five Pe famenvalve 2007-6-27 06477 famenvalve 2005-6-29 14:50
预览 ASTM A 537/A 537M-95 famenvalve 2007-6-27 06377 famenvalve 2005-6-29 14:50
预览 ASTM A 49-01 Standard Specification for Heat-Treated Carbon Steel Joint Bars, famenvalve 2007-6-27 06324 famenvalve 2005-6-29 14:50
预览 ASTM A 437/A 437M-01a Standard Specification for Alloy-Steel Turbine-Type Boltin famenvalve 2007-6-27 06999 famenvalve 2005-6-29 14:50
预览 ASTM A 389/A 389M-03a Standard Specification for Steel Castings, Alloy, Speciall famenvalve 2007-6-27 06526 famenvalve 2005-6-29 14:50
预览 ASTM A 3-01 Standard Specification for Steel Joint Bars, Low, Medium, and High C famenvalve 2007-6-27 06345 famenvalve 2005-6-29 14:50
预览 DIN EN ISO 13920:1996 yahoocomcn 2007-6-18 08100 yahoocomcn 2005-6-23 12:42
预览 DIN EN ISO 6508-2:1999 yahoocomcn 2007-6-7 07761 yahoocomcn 2005-6-8 10:33
GMT+8, 2026-7-18 23:00 , Processed in 0.025415 second(s), 13 queries .
