收藏本版 (16)|订阅
Heat Treatment 今日: 0|主题: 421|排名: 13
预览 [Solved] what mean:LF+VD xjalmh 2008-7-31 1011044 catcmt 2010-2-19 16:46
预览 [Translation] Mechanical properties claus 2007-12-3 1013415 ych 2010-2-19 11:13
预览 [Translation] Help to translate it 小乐 2010-1-31 36537 mvp 2010-2-1 15:14
预览 [Translation] Metallurgical characteristics for through hardened gearing 心情 2009-7-23 77483 xw550823189 2010-1-30 22:23
预览 [Translation] NOTE:CASE HARDEN 50 ROCKWELL C 0.2~0.3 DEEP  ...2 小蔡 2007-8-29 2620187 dhzhou888 2010-1-21 01:00
预览 [Help] How to understand this term in Taiwan TED_WANG 2007-6-7 1511260 ZX771 2010-1-2 02:28
预览 [Translation] Air cooled xingbao02 2008-1-24 710388 wingman1985 2009-12-7 16:03
预览 [Translation] OVER-AGED AND FURTHER AGED different? 混在西北 2009-12-2 67001 陆丰 2009-12-4 07:45
预览 [Share] Heat-Treatment Troubleshooting wcdi 2009-10-20 68267 panpandada 2009-12-2 08:44
预览 [Share] Heat treatment used in both Chinese and English vocabulary liudq 2009-3-15 1912351 hitfengye 2009-11-21 10:37
预览 [Help] please translate this sentence yingxunxue 2009-10-26 68123 Steven 2009-10-30 19:27
预览 [Translation] CQI-9 translation microsoft 2009-8-10 47868 wingman1985 2009-10-24 08:47
预览 [Translation] revenido aaaacym 2009-9-25 15729 wingman1985 2009-10-20 14:10
预览 [Help] revenido aaaacym 2009-9-25 16629 czwjn 2009-9-28 08:16
预览 [公告] Modelling of temperature evolution on metals during laser hardening process.pdf burt_shi 2009-9-17 07141 burt_shi 2009-9-17 00:16
预览 [公告] Prediction of laser transfo burt_shi 2009-9-17 07244 burt_shi 2009-9-17 00:14
预览 [公告] Theoretical and experimental studies... burt_shi 2009-9-17 07228 burt_shi 2009-9-17 00:13
预览 [公告] Thermal modelling of laser burt_shi 2009-9-17 06980 burt_shi 2009-9-17 00:08
预览 [公告] Effect of laser surface har... burt_shi 2009-9-17 07082 burt_shi 2009-9-17 00:06
预览 [公告] LASER PROCESSING OF MATERIALS FOR AUTOMOTIVE APPLICATIONS.pdf burt_shi 2009-9-17 06969 burt_shi 2009-9-17 00:05
预览 [公告] Laser processing of materia... burt_shi 2009-9-17 07139 burt_shi 2009-9-17 00:03
预览 [Translation] Blanking heinrich3688 2008-7-8 138413 fanhongkai 2009-9-16 16:44
预览 [公告] Experimental study of laser... burt_shi 2009-9-16 07447 burt_shi 2009-9-16 04:43
预览 [公告] Low-power laser hardening of steels burt_shi 2009-9-16 07458 burt_shi 2009-9-16 02:12
预览 [公告] The influence of different conditions of laser-beam interaction in ... burt_shi 2009-9-15 17812 burt_shi 2009-9-16 02:09
预览 [公告] Modelling of temperature evolution on metals during laser hardening process.pdf burt_shi 2009-9-15 08005 burt_shi 2009-9-15 22:52
预览 [公告] Laser hardening of pressed and sintered steels.pdf burt_shi 2009-9-15 08031 burt_shi 2009-9-15 22:33
预览 [公告] Surface hardening of steel using a high power diode laser.pdf burt_shi 2009-9-15 07286 burt_shi 2009-9-15 22:31
预览 [公告] heat transfer model for cw laser material processing.pdf burt_shi 2009-9-15 08540 burt_shi 2009-9-15 22:29
预览 [公告] HEAT TREATMENT OF AUTOMOTIVE.pdf burt_shi 2009-9-15 07150 burt_shi 2009-9-15 22:27
GMT+8, 2026-6-28 16:13 , Processed in 0.024011 second(s), 14 queries .
