〖国外标准〗 今日: 0|主题: 1098|排名: 58
预览 BS EN 746-8-2000 工业热处理设备.淬火设备的特殊安全要求 zhengcj 2011-10-23 07795 zhengcj 2011-10-23 15:50
预览 BS EN 746-5-2000 工业热处理设备.盐浴热处理设备的特殊安全要求 zhengcj 2011-10-23 07804 zhengcj 2011-10-23 15:49
预览 BS EN 746-4-2000 工业热处理设备.热浸电镀热处理设备的特殊安全要求 zhengcj 2011-10-23 08285 zhengcj 2011-10-23 15:47
预览 BS EN 746-3-1997 工业热加工设备.环境气体产生和使用的安全要求 zhengcj 2011-10-23 07266 zhengcj 2011-10-23 15:47
预览 BS EN 746-2-1997 工业热处理设备.燃烧和燃料处理系统的安全要求 zhengcj 2011-10-23 08283 zhengcj 2011-10-23 15:46
预览 BS EN 746-1-1997 工业热处理设备.工业热处理设备常规安全要求 zhengcj 2011-10-23 05247 zhengcj 2011-10-23 15:44
预览 ASTM B221M-2007 铝及铝合金挤压棒、线、型、管材检测标准(公制). gx880324 2011-10-23 07052 gx880324 2011-10-23 11:38
预览 SAE J444-2005 cast shot and grit size specification for peening and cleaning zhengcj 2011-10-18 05602 zhengcj 2011-10-18 11:52
预览 SAE J827-1996 HIGH-CARBON CAST-STEEL SHOT zhengcj 2011-10-18 06113 zhengcj 2011-10-18 11:51
预览 EDS-M-3204 Cr free- phosphating on metals zhengcj 2011-10-13 05694 zhengcj 2011-10-13 13:54
预览 EDS-M-3101 electrolytically deposited coating zhengcj 2011-10-13 07243 zhengcj 2011-10-13 13:51
预览 EDS-M-2103 aluminum and aluminum alloy sheets and strips zhengcj 2011-10-13 05033 zhengcj 2011-10-13 13:50
预览 EDS-M-1803 cold rolled steel strips for spring zhengcj 2011-10-13 06064 zhengcj 2011-10-13 13:49
预览 EDS-M-1601 alloy steels for machine structual use zhengcj 2011-10-13 05500 zhengcj 2011-10-13 13:48
预览 EDS-M-1501 carbon steels for machine structral use zhengcj 2011-10-13 06820 zhengcj 2011-10-13 13:46
预览 EDS-M-1104 rolled steels for general structural use zhengcj 2011-10-13 06048 zhengcj 2011-10-13 13:45
预览 EDS-M-1102 hot-rolled steel sheets and strips zhengcj 2011-10-13 06478 zhengcj 2011-10-13 13:44
预览 EDS-M-1101 cold rolled carbon steel sheets and strips zhengcj 2011-10-13 05454 zhengcj 2011-10-13 13:42
预览 SAE-J1268-1995 hardenability bands for carbon and alloy steels zhengcj 2011-10-9 07395 zhengcj 2011-10-9 16:44
预览 ASTM E1019-08 钢中碳、硫、氮、氧含量测定方法(英文版) zhengcj 2011-10-9 08501 zhengcj 2011-10-9 16:32
预览 ASTM A290-02 减速齿轮齿圈用碳素钢及合金钢锻件标准规范(英文版) zhengcj 2011-10-9 07676 zhengcj 2011-10-9 16:27
预览 AGMA 6006-a03 standard for design and specification of gearbox for wind turbines zhengcj 2011-10-9 06537 zhengcj 2011-10-9 16:06
预览 JIS G 4804-2008 易切削钢(日文版) zhengcj 2011-10-1 05059 zhengcj 2011-10-1 13:23
预览 ISO 6507-4 (2005) 维氏硬度检验 第四部分 硬度值表 zhengcj 2011-9-30 07312 zhengcj 2011-9-30 13:49
预览 ASTM A541/A541M-05 压力容器部件用经淬火和回火的碳素钢及合金钢锻件 zhengcj 2011-9-30 07144 zhengcj 2011-9-30 08:26
预览 ASME A266/A266M-03 压力容器部件用碳素钢锻件 zhengcj 2011-9-28 07045 zhengcj 2011-9-28 12:36
预览 ASTM A234-10 中温与高温下使用的锻制碳素钢及合金钢管配件 zhengcj 2011-9-27 07054 zhengcj 2011-9-27 13:24
预览 JIS_G0555-2003 钢中非金属夹杂物的显微实验方法 英文版 zhengcj 2011-9-26 08051 zhengcj 2011-9-26 10:05
预览 ASTM E3-01 Standard guide for preparation of metallogruphic specimens zhengcj 2011-9-25 06112 zhengcj 2011-9-25 20:27
预览 ASTM E381附件图片 zhengcj 2011-9-23 08717 zhengcj 2011-9-23 08:18
GMT+8, 2026-7-19 04:44 , Processed in 0.025165 second(s), 14 queries .
