〖国外标准〗 今日: 0|主题: 1098|排名: 58
预览 JIS 20G3109-1994 sdqdsd1976 2009-7-24 05452 sdqdsd1976 2009-7-24 11:26
预览 SAE J995 钢制螺帽材料及机械性能要求 rob!n 2009-7-21 05734 rob!n 2009-7-21 11:46
预览 BS EN 10270-3-2001_wire for mechanical springs-Stainless spring steel wire lizh020092 2009-7-20 05299 lizh020092 2009-7-20 08:37
预览 BS EN 10270-2-2001_wire for mechanical springs-Oil hardened and tempered spring lizh020092 2009-7-20 05497 lizh020092 2009-7-20 08:36
预览 BS EN 10270-1spring steel wire-cold drawn unalloyed lizh020092 2009-7-20 05747 lizh020092 2009-7-20 08:34
预览 JIS G3313-2005 电镀锌钢板及钢带(日文版) tdragonfu 2009-7-9 05693 tdragonfu 2009-7-9 14:46
预览 JIS G3313-1998 电镀锌钢板及钢带(中文版) tdragonfu 2009-7-9 06959 tdragonfu 2009-7-9 14:42
预览 AMS 2753B mvp 2009-6-29 06540 mvp 2009-6-29 20:18
预览 BOSCH标准(材料定货规范 一般用途易切削钢) mvp 2009-6-29 05687 mvp 2009-6-29 20:12
预览 BOSCH标准(材料定货规范 滚珠和滚柱轴承钢) mvp 2009-6-29 05638 mvp 2009-6-29 20:11
预览 BOSCH标准 mvp 2009-6-29 04776 mvp 2009-6-29 20:10
预览 英文版的“ASTM B447-07 焊接铜管的标准规范” harlan 2009-6-23 04799 harlan 2009-6-23 09:48
预览 DIN6773-2到DIN6773-5 英文版《钢铁材料热处理.热处理件.图样画法及标注》 gaoss 2009-6-21 97033 gaoss 2009-6-21 21:26
预览 DIN 17182 sszzrr910 2009-6-20 05788 sszzrr910 2009-6-20 20:44
预览 ASTM A897-06 等温淬火球墨铸铁件标准规范. 新绿 2009-6-17 05591 新绿 2009-6-17 22:55
预览 ASTM G 85-98 电镀盐雾试验标准中文版 新绿 2009-6-17 06391 新绿 2009-6-17 22:50
预览 ASTMA579-04_超高强度合金钢锻件 新绿 2009-6-17 04664 新绿 2009-6-17 22:46
预览 ASTM A536《球墨铸铁件》中文版 新绿 2009-6-17 06544 新绿 2009-6-17 22:42
预览 ASTM A 123/A123M-09 yang730512 2009-6-17 04758 yang730512 2009-6-17 15:35
预览 热电偶及均匀性规范 shhjm 2009-6-11 06256 shhjm 2009-6-11 11:51
预览 DIN1654-1-89 cyqkobe 2009-6-9 06019 cyqkobe 2009-6-9 16:23
预览 ISO 2768 cyqkobe 2009-6-9 05396 cyqkobe 2009-6-9 12:15
预览 SUS440C金相图 浪迹天涯 2009-6-7 06154 浪迹天涯 2009-6-7 16:22
预览 SS-EN 10204 metallic products- types of inspection documents tong 2009-6-3 06096 tong 2009-6-3 21:48
预览 SS-EN 10020 definition and classification of grade of steel tong 2009-6-3 05478 tong 2009-6-3 21:43
预览 DIN 6773 钢铁材料热处理图样画法及标注 ynajixing 2009-5-31 06179 ynajixing 2009-5-31 10:29
预览 DIN EN1706 铝及铝合金铸件--化学成份和机械性能 xzhen2008 2009-5-29 06101 xzhen2008 2009-5-29 09:38
预览 BS EN 10085-2001 氮化钢.交货技术条件 tdragonfu 2009-5-22 06694 tdragonfu 2009-5-22 18:53
预览 SAE J1975 CASE HARDENABILITY OF CARBURIZED STEELS cqujeremy 2009-5-22 05884 cqujeremy 2009-5-22 15:54
预览 ISO_6336-5_2003 dclyun88 2009-5-20 05981 dclyun88 2009-5-20 21:18
GMT+8, 2026-7-19 04:44 , Processed in 0.025466 second(s), 13 queries .
