〖国外标准〗 今日: 0|主题: 1098|排名: 58
预览 ASTM A370-2009 钢产品机械测试的试验方法及定义 米兰妖刀 2009-4-6 06578 米兰妖刀 2009-4-6 17:27
预览 ISO 9227-2006 yz-wm 2009-4-5 05043 yz-wm 2009-4-5 19:02
预览 ASTM标准中英对照目录 nanble 2009-4-2 18685 nanble 2009-4-2 10:25
预览 MIL STD 410和MIL T 6845D nanble 2009-4-2 05324 nanble 2009-4-2 10:10
预览 SAE 标准目录 nanble 2009-4-2 05707 nanble 2009-4-2 10:00
预览 美国航空金属材料标准(SAE-AMS)中相关无损检测的标准题录 nanble 2009-4-2 05381 nanble 2009-4-2 09:58
预览 BS ISO 14341-2008 Welding consumables — Wire electrodes and deposits for gas shi tdragonfu 2009-4-1 05944 tdragonfu 2009-4-1 04:27
预览 ASTM A 366/A 366M-97 Standard Specification for Commercial Steel (CS) Sheet, Car tdragonfu 2009-3-31 07345 tdragonfu 2009-3-31 20:55
预览 ASTM D 6482-2001 Test Method for Determination of Cooling Characteristics of Aqu tdragonfu 2009-3-31 05770 tdragonfu 2009-3-31 20:12
预览 BS EN ISO 14001:2004 Environmental management systems - Requirements with guidan zhnzhnzhn 2009-3-28 05765 zhnzhnzhn 2009-3-28 21:30
预览 BS EN 10208-2:1997 Steel pipes for pipelines for combustible fluids - Technical addle 2009-3-27 05568 addle 2009-3-27 11:48
预览 DIN 17022-2 Heat treatment of ferrous materials - Heat treatment methods Part 2: addle 2009-3-26 05430 addle 2009-3-26 23:49
预览 DIN 17022-1 Heat treatment of ferrous products - Hardening and tempering addle 2009-3-26 05321 addle 2009-3-26 23:36
预览 ISO 10124:1994(E) Seamless and welded (except submerged arc-welded) steel tubes 草原之鹰 2009-3-26 05345 王钰德 2009-3-26 14:20
预览 JIS G 0202-1987 Glossary of Terms Used in Iron or Steel (Testing)(日文) liyi911 2009-3-19 05744 liyi911 2009-3-19 14:49
预览 DIN 50600-1980 Testing of metallic materials; Metallographic Micrographs; Pictu luoy10227 2009-3-19 05649 luoy10227 2009-3-19 14:35
预览 ASTM A 1016/A 1016M-04a Standard Specification for General Requirements for Ferr tdragonfu 2009-3-17 05838 tdragonfu 2009-3-17 21:35
预览 ASTM E384-05a Standard Test Method for Microindentation Hardness of Materials1 tom2005 2009-3-16 05482 tom2005 2009-3-16 22:45
预览 ASTM E92-82 Standard Test Method for Vickers Hardness of Metallic Materials1 tom2005 2009-3-16 07400 tom2005 2009-3-16 22:43
预览 ASTM E18-00 Standard Test Methods forRockwell Hardness and Rockwell Superficial tom2005 2009-3-16 06073 tom2005 2009-3-16 22:40
预览 ASTM E10-01 Standard Test Method for Brinell Hardness of Metallic Materials1 tom2005 2009-3-16 05540 tom2005 2009-3-16 22:34
预览 BS 183-1972 一般用镀锌钢丝多股绞合线规范(英文版) tdragonfu 2009-3-16 06488 tdragonfu 2009-3-16 15:47
预览 DIN 17022.3-1989 钢铁材料热处理.热处理方法.表面硬化处理 tdragonfu 2009-3-15 05526 tdragonfu 2009-3-15 13:30
预览 DIN 17021.1-1976 钢铁材料热处理.材料选择.基于淬硬选择钢材 tdragonfu 2009-3-15 05173 tdragonfu 2009-3-15 13:28
预览 ASTM A537/A537M-2006 压力容器用经热处理的碳锰硅钢板 tdragonfu 2009-3-15 05679 tdragonfu 2009-3-15 13:21
预览 AMS 2759 3C (中文) 沉淀硬化不锈钢和马氏体时效钢的热处理 luoluo771 2009-3-15 06811 luoluo771 2009-3-15 09:54
预览 AMS 2759 Heat Treatment of Steel Parts General Requirements luoluo771 2009-3-15 06931 luoluo771 2009-3-15 09:25
预览 ASTM E 1444 Standard Practice for Magnetic Particle Testing cqujeremy 2009-3-13 06783 cqujeremy 2009-3-13 13:06
预览 ISO25531992焊接·硬钎焊和软钎焊接头图样上的符号表示法中文版 bdlhj 2009-3-13 05347 bdlhj 2009-3-13 11:43
预览 JIS G3141-2005 冷轧钢板及钢带 fcjyiong 2009-3-12 05461 fcjyiong 2009-3-12 09:41
GMT+8, 2026-7-19 00:00 , Processed in 0.025538 second(s), 13 queries .
