楼主: 温庆远
推荐一种新的淬火工艺
 火.. [复制链接]
 楼主| 发表于 2010-6-9 20:57:28 | 显示全部楼层
zhaozhihua
您可以到《热处理》Heat Treatment     2005年20卷4期,分类号GT156.3.1  作者:樊东黎查找。
 楼主| 发表于 2010-6-9 21:00:57 | 显示全部楼层
缩短渗碳周期与强烈淬火相结合的节能热处理技术(英文)--《热处理》2007年02期
本文献来源中国知网 www.cnki.net
  在热处理行业,人们一直在探索降低生产成本、节约能源和减少环境污染的方法。汽车制造业在这方面将是大有作为的,其中包括:大幅度缩短渗碳时间,以节能和降低生产成本;开发新型淬火剂替代易燃、有毒的矿物油基淬火剂。采用非易燃的对环境友好的水基淬火剂进行强烈淬火(IQ)是达到这些目标的途径之一。此外,IQ还能使渗碳的扩散时间缩短50%或更多。本文论述了巴西圣保罗大学、巴西Combustol公司以及美国强烈淬火公司合作进行的采用一种强烈淬火工艺成功达到上述目标的研究成果。从长远看,这些成果对热处理工业将具有重要意义。
【作者单位】:EESC-University of Sao Paulo Sao Carlos;Brazil;EESC-University of Sao Paulo;Sao Carlos;Brazil;Isoflama Ind.E Com.De eq.;Ltda.;Indaiatuba;Brazil;国际热处理与表面工程联合会
【关键词】:强烈淬火;渗碳;压应力
【分类号】:TG156.81;TG156.3
【DOI】:CNKI:ISSN:1008-1690.0.2007-02-016
【正文快照】:
  1IntroductionIt is known that the higher the quenching rate offerrous alloys,the higher the probability of part distor-tion and part cracking.Despite this,studies conductedin the Ukraine by Dr.Nikolai I.Kobasko,show thatwhen quenching rates are extremely high,the potentialof formation of part cracks and part distortion becomevery lowas seen in figure1.In addition to this,super-ficial compressive stresses tend to grow as well as fa-tigue strength[Aronov et al,2002],[Totten et al.,2002],[Koba…
 There is an ongoing interest in the heat treatment industry to identify methods of reducing production cost,energy consumption and to reduce environmental impact of heat treatment practices and materials.Automobile industry offers a number of opportunities in this regard including:reduction of substantial carburizing times which would result in substantial energy savings and reduction in production costs due to shorter processing times and the potential replacement of flammable and relatively toxic petroleum-based quenchants.One way of achieving these goals is to use intensive quenching processes(IQ)which utilize non-flammable and environmentally benign aqueous-based quenchants.Furthermore,IQ offers the potential of significantly reducing total carburizing diffusion times by 50%,or more.This paper will discuss the results of a collaborative study conducted by the University of Sao Paulo at Sao Carlos,Combustol,and Intensive Quenching Technologies to utilize an IQ process to successfully achieve the afore mentioned goals.These results are potentially of major importance to the heat treatment industry.
【Keyword】:intensive quenching;carburizing;compressive stresses
参与人数 1热处理币 +15 贡献值 +15 收起 理由
孤鸿踏雪 + 15 + 15 感谢上传!
签到天数: 9 天
发表于 2010-6-10 08:54:10 | 显示全部楼层
这种工艺在一些大件热处理厂早有应用,特别是对一些中碳调质钢不但进行了水淬,而且已进行了盐水淬,效果的确很好。
签到天数: 40 天
发表于 2010-6-11 11:47:40 | 显示全部楼层
zhaozhihua
温庆远 发表于 2010-6-9 20:57
    谢谢温专家的回复,也感谢专家给提供的相关信息。我查查看。。。
签到天数: 1781 天
发表于 2010-8-2 10:24:54 | 显示全部楼层
我们公司的淬火池容积将近400³,使用的就是盐水,我想应该是目前最经济的淬火方式,当然在材料上肯定有所限制,其实国外已经比较普遍了。我们目前生产的材料以碳钢、中低碳合金钢为主,效果也不错,主要产品都是出口到世界各地的。公司投产前请了很多国外的专家来我公司进行指导,在西南地区我公司的调质炉也是最大的,装炉量可以到20t最大。
发表于 2010-8-9 09:21:39 | 显示全部楼层
我在4340.43304130.4140.4142.4135.等都淬水。
发表于 2010-8-19 13:11:42 | 显示全部楼层
40Cr单件2公斤以上的我们一直是用清水淬火的。效果很好。
签到天数: 79 天
发表于 2010-8-22 07:31:31 | 显示全部楼层
回复 19# 温庆远
    “把马氏体控制在30%上下。
     我感兴趣的是马氏体转变速度是是纳秒级(nS),居然能够控制。确实不简单。这将是向传统热处理的一次挑战。”
马氏体的转变速度虽然很快,但是个随温度降低的连续转变过程,而在上下马氏体点区间不同的温度对应不同的马氏体量,而这个温度还是容易控制的。
 楼主| 发表于 2010-8-22 11:08:18 | 显示全部楼层
回离别钩
您如果对此感兴趣可以参考前面提级的有关资料。
签到天数: 6 天
发表于 2010-8-22 19:04:00 | 显示全部楼层
回复 4# 孤鸿踏雪
    有原文吗,我在网上搜索了下, 不能下载!!希望上传
发表于 2010-8-22 19:10:25 | 显示全部楼层
回复 31# Diego001
    我这儿上传有些困难,主要是扫描仪坏了,得到分司去扫描。
发表于 2011-4-26 08:31:25 | 显示全部楼层
液氮淬火也是可以考虑的
发表于 2011-4-26 08:43:37 | 显示全部楼层
超冷速淬火主要想法就是通过人为调整冷却速度使得工件表面或近表面的应力状态为压应力。那就是说,要使冷却时产生的表面拉应力被马氏体相变产生的表面压应力抵消,而快速冷却能使得这两者同时发生。这就要求在超快冷却之前必须做好预处理(工件内部压力为拉应力)
签到天数: 523 天
发表于 2011-4-26 09:52:55 | 显示全部楼层
回复 7# 红与黑
    我经常做超温短时回火,我们小批量调质件淬火后,(当然是小件)回火时装入做正火件的正火炉,同正火件一同升温,当升温至比调质件预订回火温度高出100--110度时将调质件拉出,(一般硬度都能符合技术要求),正火件再继续升温。
发表于 2011-5-21 08:25:06 | 显示全部楼层
回复 1# 温庆远
    强烈淬火法:可以不可以这么理解:
1.能更好的控制淬火介质温度,换句话说,淬火介质的温度能保持恒定;
2采用高速水(或其它介质)流喷淋零件时,可以起到吹砂抛丸的作用,能在淬火的同时就能抵消冷却时所产生的一部分热应力和组织应力,
所以用这种办法能减少开裂变形  是可行的
发表于 2011-5-21 09:46:59 | 显示全部楼层
个人浅见:可能比较适合超大型工件淬火,从而提高有效淬硬层深度。
发表于 2011-5-21 19:37:13 | 显示全部楼层
学习了   这项技术应该是将淬火液的蒸汽膜阶段、沸腾阶段、对流阶段分开控制冷速吧,也就是要达到手册上说的最佳淬火液的效果,恐怕要有高端淬火设备才能实现
发表于 2011-5-23 16:47:00 | 显示全部楼层
再结晶退火的工艺方法
再结晶退火 将材料加热至再结晶温度以上,保温后缓慢冷却的工艺方法。
    完全退火用于亚共析碳钢和合金钢的铸、锻件;等温退火用于奥氏体比较稳定的合金钢;球化退火用于共析钢、过共析钢和合金工具钢;均匀化退火用于高质量要求的优质高合金钢的铸锭和成分偏析严重的合金钢铸件;去应力退火用于铸件、锻件、焊接件、冷冲压件及机加工件;再结晶退火主要用于去除加工硬化。
发表于 2011-5-23 17:23:53 | 显示全部楼层
回复 19# 温庆远
马氏体转变速度是纳秒级,是指一个M片的形成长大时间。
马氏体转变量是可以控制的。
发表于 2011-7-16 17:07:55 | 显示全部楼层
温工多少大的水流才算高速水流,我们淬火是用水泵打压自动喷淋的算是高速水流吗?我们一直采用这种方法,效果还可以。
GMT+8, 2026-6-13 19:54 , Processed in 0.036473 second(s), 19 queries .
